Dual alternator and batteries in 11 Tahoe
what will you be using that will draw the extra current? one alt. will charge both batteries, just a little slower. your alt. needs to be sized to carry the load of the truck and its accessories. 2 batteries do not require 2 alts.
most 2 battery setups are to protect the starting battery form discharge from things like slide in campers and other things used when the truck is turned off.
As others have said, under most circumstances dual alternators are not required with dual batteries. It all depends on the amount of amperage draw you need at a given time, how frequently you call for that draw, your current recharge rate capability.
DEWFPO
Im going to be powering a 10,000 watt stereo, The last one I installed in my car with a 160amp HO alternator put a severe drain on the system, that stereo was only 4,000 watts. so I was looking at the 2nd alternator bracket with a 200 amp HO alt.
    • Still $3.01 with even more places at this price
    • JW2024 and Others is this site for Oshawa built Trucks as well ? Thank You !
    • Thanks JR that would be great if you could do that !!! Do you have a link to where this was discussed before ? I cant seem to find it  Thank You Again !
    • Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
