I am considering a 33" tire with a 2" level.
Fallz
I have a 2" daystar leveling kit . Truck measure 39" front from ground to fender lip . I found some General Grabber AT2 tires but the closest I can come to a 1" larger tire (32.5) is a 33" . My stocker Bridgestones are 31.5 . Otherwise I might do Nitto Terra grapplers .
Think it will fit a stock rim for now ?? I plan on aftermarket rims in spring or when I find one I like .
I would just do the 32.5 inch. these newer GM's don't have a lot of room for big rubber even with the leveling kit. Im assuming they are 285's and thats the biggest I would for now till you want to do either a BL or lift kit. You may also still have some rubbing with the 285's.
I'm running 285-70/17 (33") Toyo OC A/T tires on stock rims with essentially no lift.
I've got the Daystar 2" as well, and run Toyo AT's. 285/70/17. No rubbing, and required no trimming. And for what it's worth they're proving to be a great tire. Pics in my album if you're interested.
OK thanks guys . I might go for the GY Duratrac. Just gotta decide if Im going to stay with 18's or go to 17's .
Our specs are ..... 6 on 5.5 correct ?
Yes....and factory offset is +31mm
Btw, my setup is in my sig...and they just rub the mud flaps when I back-up with the wheels cranked
