Trans cooler
i didnt say it was easy, and approx 9000 loaded no fuel in the trailers tank. and stopping well you have to ride the trailers brake sown the grade. should i be towing that weight? thats an opinionated question, many people have various thoughts and theories based on the truck and driving experience. i can do it and i have. i dont do it often. my normal haul is a 18 ft horse trailer with about 5 pigs or 3 steers.
  • Replies 68
Here are the specs on that vehicle from cars.com:
http://www.cars.com/...e&&aff=national
Curb weight 4,563 lbs.
GVWR 6,200 lbs.
Front GAWR 3,600 lbs.
Rear GAWR 3,686 lbs.
Payload 1,637 lbs.
Front axle capacity 3,600 lbs.
Rear axle capacity 3,750 lbs.
Front spring rating 3,739 lbs.
Rear spring rating 3,686 lbs.
Towing capacity 8,100 lbs.
GCWR 13,000 lbs.
Subtract the Curb weight of 4,563# from the GCWR of 13,000# and you have a max tow capacity of 8437# minus the weight of the driver, passengers and cargo.
These ratings are a lot higher than the ratings on the newer vehicles.
Personally............... I wouldn't tow a 9K# trailer with that truck. Not only do you risk messing up the trans and other mechanical parts of the trauck but if you have to make a panic stop with that rig, someone is going to be in a world of hurt.
The tongue wt on that trailer has got to be well over 1,000# and I'm pretty sure that you will have passengers and cargo in the truck.. That is really the job of a 3/4 or 1-ton truck.
You mentioned "Riding the trailer brakes". NOT a good idea. It's best to use the break controller (propery adjusted for the conditions) to distribute the load (heat) to all of the brakes at once to keep from over-heating the trailer brakes.
Once you over-heat the trailer brakes, they are useless and now you are depending on the truck brakes alone to slow this 15,000# load. Those brakes are designed to handle a maximum of a 6200# load (GVWR) on their own and will soon fade as well...... then...... just bend over and kiss your a$$ good-bye because you will have a run-away rig.
It would be a lot cheaper and safer (in the long run) to sell that truck now, while it is in good condition) and upgrade to a 3/4 ton truck with a factory tow package. IMHO, you may spend a lot more than the cost of that upgrade in repairs to that vehice. In the end, you will still be faced with doing the upgrade anyway.
i tow this trailer once a year at most. and we have a 3/4 ton truck, mine is the back up if the dodge fails. like last year the transfer case grenaded
Regardless of anything, it should be mentioned that in the stack of two lines that are on the side of the transmission, the top one is the return line (FROM the oil cooler) This should be almost without argument. I have snow and ice on the ground right now. When it clears up I'll go trace the lines from tranny to radiator.
From my installation of the original equipment cooler kit, the transmission oil comes out the TOP of of the vehicle's radiator. UNLESS on the OEM installation of the auxilary oil cooler they had it plumbed so that the auxiliary cooler (air to oil) is in line BEFORE the vehicle's radiator.
Prior to this thread, it had been nearly universally accepted on this board that the upper outlet of the radiator was the return line to the transmission.
If this was incorrect information and I screwed up your install I sincerely apologize for it.
i was told lower line was return, so it wasnt you, im having a hit of bad weather so i havent changed my lines back around
Did you physically check yours by running the engine and checking?
no ii followed the advice. i have yet tried to fix my mistake, been a little too busy this week
If the lines are pointed down, the cooler will drain back into the trans when the engine is off. You don't want that.
The oem cooler has the lines pointed down, with no problems.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
