Trans cooler
Just look through the damn grill, no need to take anything apart. I don't mean to be short but you're about to throw money away if you already have one in place, I wouldn't even begin to worry about 200 degree trans temp, everything I've seen says 250 is the number when you should start worrying.
  • Replies 68
when its winter and its hitting that i worry. i live in the desert. and i know i had the grille off previously to install my billet. i had to cut out the stock grille
keep in mind that your transmission fluid does in fact pass through the trucks radiator (lines are on the passenger side at the top). This will HEAT your transmission fluid to approximately the coolant temperature of the trucks engine, the auxillary cooler will mount in line with this system after the radiator to further cool transmission fluid. 200* is nothing to worry about, I would regularly run 185-200 in my '03 4.8 Silverado.
Got my cooler. Which line do I tap into on the radiator? Upper or lower? I'm not sure which is the return line.and just a side note what's the slim cooler on the trucks left side . Its tall and narrow and about an inch thick.
I just want to make sure I do this right
The lower line coming out of the radiator is the output line. IN at the top, OUT at the bottom. The other cooler you mention may be a power steering fluid cooler. Follow the lines.
DEWFPO
ok so ill be completing this tomorrow. thanks for the info
I know i dont i pulled the grille off my truck...
I do like that little fan what size is that ill be getting the 11x7-1/2 super cooler
I used this trans cooler:
http://www.amazon.co...6522111&sr=8-10
You will need one of these fittings fot the radiator:
http://www.amazon.com/Hayden-Automotive-397-Transmission-Fitting/dp/B000EPRCAC/ref=pd_sim_auto_2
This is the 9" version of the pusher fan that I installed (the one that I got was 11"). I just attached it to the cooler with plastic wire ties (doubled up).
http://www.amazon.co...26517237&sr=8-1
This is the relay that I used:
http://www.amazon.co...26517403&sr=8-8
I attached the hot side to the battery (with the included 30A inline fuse). I spliced the activator wire to the trucks radiator cooling fan. Then the other side goes to the pusher fan. That way, the pusher fan only runs when the radiator fan runs and the power comes from the battery so that your radiator fan circuit is not over-loaded.
Pull the upper trans cooler line off the the radiator. Clamp one end of the rubber hose directly to the trans cooler line. It has a barb on it. Install the proper fitting on the ratiator and clamp the other hose on that fitting.
Be sure to mount the cooler with the hoses coming out the side (like in my pic). Never install a trans cooler with the pipes coming out the bottom. Top is OK but you may not have enough room.
Just my opinion, a transmission without an external cooler, is just a problem child........ When I build one I always put a cooler on the vehicle if it didn't have one.
Ya, you have one in your radiator, but its more to warm the fluid when the fluid is cold than remove heat. Think about it. Your engine is 195-210 the coolant in the radiator tank is that tooooooo.
I tow frequently with my 4L80e in my 3/4 ton, with nothing behind it the temps are around 160 and 180 with a trailer. After I made a little upgrade to my cooler. Before 170 and 220.......
Jbo
175 C or F?
175C = 375F, if it were to get that hot it would burn it's self up in about 200 miles lol
175 C or F?
Ya I guess that was dumb to ask.
DEWFPO
Wrong. It's the other way around. The transmission fluid enters the radiator at the bottom inlet and exits through the top. This is to keep aeration from occuring (from fluid entering the top and dropping down in the cooler).
are you certain? because if this is true i have to reroute lines now and can i now have the part number for the line that comes out of the lower radiator port to the transmission. i cut the rubber line and routed in series to it
    • My house is set at 75. My car at 70. When I have guests the house is at 70.
    • OK you say you could hang meat but what was the actual temp? One of the AC systems job is to remove humidity that we feel on our body your new system removed alot of humidity as that is were the water comes from on the ac coils and that made it feel colder. 80 degrees with high humidity will feel hot vs 80 degrees with low humidity will feel alot cooler.
    • I was using recirc/max air. Especially if it really hot i start out by lowering the front windows a little with regular ac the go to recirculation after a few and rolling windows up. And it does not have the newest refrigerant. It has per the info under the hood r134. Not the new r1234yf.
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
