For MountaineerTom and EmTwo
TxDoc
You'll love this:
JavelinLiveFire Video
(may have to right click and save target as and dowload first)
Yes this video is real, the T72 was filled with black powder to simulate realistic battle conditions (full fuel tanks). The road wheels flew into the woods on both sides of the test range.
This was shot on Redstone Arsenal in Huntsville, AL.
Thanks to DsrtEgl50.The turret flew up in the air some 200 feet they estimated.... When it came back down it burried in the ground about 6 feet, the barrel was just imprinted into the ground.
With the slow motion video tools they have in the studio (at Redstone)... You could watch the turret pop off (only lasted like 3 frames of high speed video though)...
The explosion cut the power lines (when it decapitated the transformer across the road) to all but 1 of the cameras (it was battery operated)...
and
For MountaineerTom an EmTwo:
MiniGun Video 1
Take a look at:
Monty's MiniGun Page
:wtf:
Great stuff Doc...thanx.....the second tank hit is awesome.
Really enjoyed the mini-gun footage too...
Those are pretty cool.  I used to show that Javlin Live fire, along with a few others, in my Weapons Academics Class just for s&g.
I hadn't seen the mini gun one before though, pretty cool.  :thumb:  :wtf:
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
