P0171 & P01174 - Silverado Running Lean
red_chaser
I first had a check engine light for some knock sensors. I went and replaced those, took off the intake manifold, replaced the seals, cleaned my injectors, and put everything back. Torqued down the manifold screws to 44 in-lbs then 89 in-lbs, put all the hoses back, cleaned the throttle body, and re-installed the EGR hose.
The Knock sensor codes cleared and about a day later got new codes, P0171 & P0174. Did some research and it could be a vacuum leak. So I went back make sure everything was on right with some carburetor cleaner and found that the EGR hose had a leak where it plugs into the manifold. I bought a new o-ring gasket and re-installed it, drove it around for a while and the fault cleared.
The truck was running nice. Even a rattling nose it had upon hard acceleration went away. Tons of power and acceleration. Two days later the same P0171 & P0174 codes came back. I am at a dead end. Could be the MAF, O2 sensors, injectors, ect, but I don't think that is likely because the truck was running without any codes until I messed with the intake manifold.
I can still hear a leak where the EGR hose plugs into the manifold. I am thinking of using RTV around that damn hose. I'm going to take off everthing this weekend and re-install it, maybe I missed something. The pinging noise is back under load.
Is ther anything else I could try?
Any advise. Sorry for the long post, I needed to vent.
Does this cause any damage to other compontents? What about the gas mileage?
Silverado, 2001, 5.3, 4WD
The SES light has been on for 3 days straight, but today during my luch break it decides to turn off. I don't know if I should be relieved. Do you guys think it will turn on again? What could be going on?
:confused:
The SES light did come back on.
I checked it out this weekend and found I still had a leat at the EGR hose connection at the manifold. I tryed new o-ring gaskets; I even loosened up the EGR valve bracket to facilitate the manipulation of the hose, but that didn't work either. Everytime I sprayed carb cleaner the engine's idle would change.
I finally got fed up and put the o-ring gasket with a little RTV, left it over night to fully cure and no more leak! The SES light turned off and the truck runs like new. I hope the vibrations don't loosen it up or the RTV cause something else to go wrong.
I hope the SES light doesn't come back any time soon.
How else could I have gotten the EGR hose not to leak? That one screw and flimsy aluminum bracket on that hose suck!
  • 3 weeks later...
I'm getting these same two codes. I plan to clean my MAS and check all vacuum hoses tomorrow. Is there a way to check the functionability of the O2 sensors? I'd rather not replace them unless I can first determine they're in need of replacement.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
