Dual exhaust advice
Any body have any input on this system?
Flowmaster 817492 Cat-Back System 409S Dual Rear/Side Exit Force II Moderate Sound Exhaust Kit. Amazon.com has this for sale at $443.99.
Is this a good kit worth doing? How is the sound? Noisy?
Thanks guys.
Personally I'd stay away from Flowmaster. I had it and although the sound was awesome, it rusted out in just under 2-1/2 years with Pa. Winters. I also lost low end torque and mileage with that kit (03 5.3L) When it rusted out, I replaced it with Magnaflow. It's full stainless steel and uses SS. bands instead of clamps. It sounded awesome and I pickedup the mileage and low end torque I lost with FM. Also very similar pricing for a full stainless system that feasibly could be your last. :thumbs:
Thanks. I am located in NJ so our winters are about the same. You made up my mind for me, I will start looking for a Magnaflow.
I am replacing the entire exhaust system on my 99 Suburban this weekend. I am installing MagnaFlow Cat system, all stainless steel from the exhaust manifolds past the catalytic converters then into a 3" pipe to a FlowMaster 50 Series muffler. Continuing the 3" pipe out of the muffler all the way out the back of the Suburban. Anybody had any issues with a single 3" pipe? I have read on a couple of forums not to use dual 3" pipes because there was not enough exhaust flow and this would decrease low end torque and power but it did improve the higher RPM performance.
Any information would help.
Jeff
If I were you I would look at a good quality stainless system. The Flowmaster will not last very long in harsh climates, they are know for rotting out. Borla, Corsa, MBRP, Magnaflow would all be good choices IMO.
I might at a later date but right now I am not setup for good stainless welding, I need to get it back on the road. If it lasts 5 years I will be happy. I live just south of the Red River in Texas so our winters aren't bad we just have really hot and dry summers. And this vehicle has 325K miles and isn't a performance ride, just a daily driver and occasional hunting rig.
Thanks for the information.
Jeff
Why weld it? Just use clamps. .. ... I see a lot of people, burn in the joints but, to each his own. If it was mine I would use a clamp or butt weld the pipes together.
What's the point in the slip fitting if your just going to weld it?
Oh yeah, I don't remember which flow master system I had but, it lasted about 8 years down in south Mississippi and it rusted out. I replaced it with a borla system. I think the system I had was 17257 it was a force II system and it was quite. Unless you got a little load on the truck.
Jbo
I'm welding the pipes together because they will butt joints not slip ons. The MagnaFlow section is slip together and that will be clamped not welded. However, the section right after the cats, where the two pipes meet at the flange, the other side needs to be fabricated into a single 3" pipe, that will all need to be welded. The 3" pipe going to the muffler will be welded to the muffler and so will the one coming out the back. I've had some bad experiences with clamping systems together and decided to weld it this time.
Jeff
Stainless pipes sometimes will not be able to get the clamp tight enough. Back in the late 70's my buddy had little Fiat. He got the full stainless system from one of the old day speed shops (Piranha). System was made by Borla. If we used the clamps, they would not crush the pipes to make it tight. Even tried heating the pipe near red hot, clamps just would not tighten enough.
We ended up slipping the system together, with all the males ends covered in RTV, and at each connection we drilled and used pop rivets. This exhaust was finished with that black crinkle finish. The male end of the pipe did not have the crinkle finish. Never had an issue with that car's exhaust after that.
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
