Darn Drums
I would just like to see some pics of this whole affair. When I did mine a couple of years the shoes didn't wear any kind of a groove in the drums. I'm just curious how these brakes actually look once they are apart.
Didn't even think to take pics of anything, and I went and turned the cores back in even though they didn't require the actual drums but the brakes. I didn't want to haul the drums around so I told them to take them but the originals were actually good, no groves so I guess you could say they were still good, except for where the drum was contacting and rusted in place.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
