Need help to fix Curb Rash :(
I agree it wont be perfect unless you replace the wheel but it can be fixed to be less noticeable. Last time I had a curb rash (on an aftermarket set tho) I called these guys http://www.awrswheelrepair.com/ and they came to me to fix it. I think $150 seems high for one wheel. I made sure to catch up with the guy when he was in my area (no special trip), offered cash and if IRCC paid less than half that for two wheels.
I know that the dealership that my wife's BMW came from has someone come on a regular basis to do work at the dealership. If you take it there they can do it but of course they are going to mark up the price. Best bet is to get a recomendation for someone local who can do this or find out who the dealerships use in your area and call them directly.
That said, I probably wouldn't worry about it cause it won't be the last curb rash you get and you will drive yourself nuts trying to keep fixing them.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
