Photoshop help?
TimmyG
Looking for someone to photoshop some rims on my truck
Heres some kinda crappy pics, i can get better ones later. And i would like to see some moto metal skull rims on it in 17s(same size as on truck now)
those skulls look funny in my opinion there eye sockets almost look like sun glasses . Kinda look cartoonie but I guess I am just biased and dont really care for the skull goth/emo look on a truck or trying to be cool middle age biker with a skull .If I was going to get skull rims i would get a much different style skull pattern . I am pretty sure if you cant find the help you need on this forum to photo shop those rims on your truck you can try a photo-shop forum.
I am sure someone on here tho will help you out, this community is awesome and I bet even some guys on here will like your rim choice to :) .
I just realized I should apologize I am sorry . Good for you that you have the money to buy what you want !
For me they dont eve look like skulls, but i like for they look, just not sure they will look good with tires and on a truck!
I can save you the trouble then. I have seen some on a truck in person, and they look silly.
Still not sure, just posted incase someone stumbles across this post
Please don't.
i dont like 100% black rims, what eles would you suggest
There are so many other nice rims out there that are black and machined. Those are just so tacky, seriously, don't, you'll regret it.
Here are just a few good alternates.
XD Addict
Fuel Hostage
This one is brand new, probably my fav of the three
MKW Off Road M88s
So glad I took the time to suggest some quality alternatives for you, really.
Sent from my Allblackedout iPhone using Tapatalk
Those are most more tastefull ! :)
I do like the xd!, but i was looking for something diffrent then everyone else. My buddys truck has dick cepek wheel on it andit looks great!
The problem is were i live there is alot of people and i like to stand out
Theres a reason those skull wheels are different thAn everyone elses. Not many people would even consider buying them.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
