GMT-900 Dominator II Nerf Bars
hodges25
I recently had my bars replaced due to rusting on the bottom of these bars so I am just trying to get rid of these. I have all the brackets and hardware except for the U-nuts as most of them broke off when I removed them. They can be had at your local hardware store. The rust isn't terrible but this would be a good opportunity for someone wanting to color-match or line-x them. I'll take 175 obo, they do go for about 350 new. Here are the pics of the rust:
I would prefer not to ship but it is a possibility. I'm in NW Florida near Destin.
really wish these would work on a CC. I would love to powder coat those things white
I'm VERY interested but is there anyway you can get me a shipping price to 61362 (to a business address with regular pickup/drop off from both UPS and FEDEX)
Thanks!
Just a couple bucks more than the last quote, since the box is so big they bill 90 lbs min weight and a large package surcharge. And without a company name and address I can't get a quote to a business, that's for residential
Do you mind me asking how long you had them on before this started happening? I have been thinking about getting a set for my truck, but being in the salt belt, I am concerned about how long they will stay nice. Thanks.
A year almost to the day, when I got them the welds for the actual steps had a small amount of powdercoat missing but I didn't see it as a big deal. The large spot seen in the photo happened sometime afterwards. I would inspect them well before you install them and if they are messed up at all try to get them fixed. The rust is all surface by the way.
  • 3 weeks later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
