P0449 code check engine light
djbrett1
I have a 2005 Chevy Suburban Z71 with 52,000 miles. The check engine light came on and the P0449 code came up stating" Evaporator Emissions Vent Control". Where Do I start?
Same code seems to happy to a lot of us around the same mileage. Check the gas cap first and then move on to testing parts. There are several post on the forums, a long post in the how-to section. Most likely it is the vent solenoid, about $15 for the old style to about $60 for the new. Just don't buy the kit from the dealer, they want $180 for it.
