taking front seats apart
i have a set of donor seats from an 02 suburban. they are tan leather. i am ordering a clazzio set. how do i dismantle the back from the seat bottom. and anyone who has a clazzio kit do i need a covering on the seat to put the kit on. it says install over cloth. i also dont know how to take the arm rest off. i got the seats $100 a piece from a junk yard. i know they run for more so i dont want to have to buy new ones
or if i can get oem ones what would be the cost?
The covers should come fitted for your vehicle. Should not need to take the seats apart, they slide right on and are very tight. The directions that come with the covers should tell you how to remove the arm rest, if it needs to be removed at all.
ok. i need to take them apart. the seats in the pic are both power. i have manual seats
Maybe I am not understanding you? You asked about installing the Clazzio covers, are you installing the power seats into your vehicle and taking the regular ones out? If so, you may also have some electrical work to do.
The seat covers are made to tightly fit OVER THE TOP of your existing OEM seat covers.
im taking the seat backs from the leather seats installing them on my current manual seat ass cushions. and i asked about other options too after i figured out clazzio was an over the top fit.
OK. Its pulling the back off the ass cushion im curious about. And after reforming I need new leather
It's easy to get the cover off the bottom portion of seat. I've had to do it before. Take the seat out of the truck, unhook the lower cushion from the seat frame, proceed to take the cover off the foam. Or more correctly, take the foam out of the cover.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 394 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
