amp wiring help URGENT!!!
i just spent the day installing my OEM nav unit, having it programmed, then wiring in the VSS harness, GPS antenna, Line-output Converter, and amp. Everything works great but now I'm stuck at the question as to how do i run the stock door speakers off the amp that i just wired in? Do i have to run new speaker wire to all the doors? Or is there an easier way in doing this?
I need help ASAP as I'm trying to get this done today because today's the only day that i have my buddies to help me with everything!
at this point in your install it will probably be easier to run new speaker wires from your amp to the doors. you'll have to snake the wires through the door jamb conduit and that can be tricky. take your time and you shouldn't have any big issues.
This is a little late, but the other option is to run all of your speaker wire to the dash to connect to your factory wiring there. Not ideal for aftermarket speakers, but fine for OEM.
Many manufactures make a 9 element cable just for running your speaker wires back up to the factory connector in the dash, from the amp. That's how mine are getting wired when I get a chance to install my amp.
