33x12.5x20 can't decide
mastrcruse
My Trail Grapps are quiet. If I went with a AT though I'd go with Mickey Thompson ATZ's. Love the sidewall on the 20's and hear they last a long time
Thanks. Yea I really liked the trails look but the noise was just getting a bit to loud. I decided and went with 305/55 20 zeons LTZ.
It may be too late now....but IMO the leveling keys are a waste of money. Just crank up your stock keys, get the front re-aligned, and you're good to go!
Well I was thinking the same thing. Some say you have to level to get 33x12.5 to fit...some say you don't. If its not necessary I don't want to waste money.
Also, I've been looking at trucks with 305/55 and they look no where near as big as my 33x12.5 trails. I know the trails ran as a big 33 but the 305s seem to look tiny.
So the shop I go to said that leveling with the stock keys would be fine but that this would cause me to have to upgrade shocks. Is this correct? $460 for front fox shocks with alignment. he's also trying to push me toward the toyos and said he has had both trails and open mts and hr said the opens are much quiter. Dang, I'm confused. I know he's running a business but first he said get the readylift kit, then he says dont, now he's saying no readylift but shock upgrade is needed.
Discount tire is going to mount one of the 305/55 20s because they believe with modification to the inner fender (jus the plastic) that I can fit these under without leveling on the 2500? Any thoughts??
I did have to level the 1500 but it looks, from research, that people are able to stuff a little more meat under the 2500s.
I would level it even if you can fit it. Atleast crank it a little to give you more clearance. My 295/55/20's measure 32.9" tall and 12.52 wide and sometimes I rub sway bar, sometimes not on 2" level on a 1500.
Leveled out with 33x12.5's on a 2500 will look good.
Just crank the bars, get it re-aligned, and go. The longer shocks, or shock extensions may help the ride a little....but they're not necessary...especially if you only go a few turns. If you were maxing them out, then maybe. I would crank them up 3-4 turns, drive it for a few days to see how you like it....raise or lower it if you're not happy...then get the alignment done. The whole shock thing can be done later if you don't like the ride
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,367 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
