Brakes? What brakes... pfff grrrr
wishybone2
2004 GMC Sierra Crew Cab z-71
Dual piston calipers Rear
No traction control
Delphi ABS with out bleeders
Soooo... I changed the the rear calipers on my "yard" "plow" truck... thats imporant for later....
That was a couple months back... Brakes got a little spongy after but NBD
So then I blew two brake lines and fixed them... Bled and they came back to OK
so I figured I would change my front calipers as well because the bleeders were stuck and I figured I wasnt getting a good release...
After changing the front calipers... NO Pressure... tried bleeding many times... well turns out the ABS module only can be bled with a tool...
Problem is my ABS motor is shorted... dont want to fix because its just a truck we use to plow the farm driveway... and thats big $$
So I say... Well I have the time I can get it to bleed.... YA RIGHT! After hours of watching air bubbles go by (open bleeder, pushdown, close, up slowly, open bleeder, push down)... I mean at least 10 hours and bleeding and tapping on everything... well I had a good pedal when the truck wasnt running but soon as it was started... right to the floor... everytime
So I said to myself... Well I can bypass all that stuff and that will get rid of the air in that pesky controller... well yep... brakes bleed great when the trucks not running... no air in the lines... but soon as i start it... bang right to the floor... OK is there somthing I need about this thing or should I just drive into the old farm pond out back....????
Thanks for your time in advance... I understand that this is kind of a modification which is a no no here but it wasnt intended to be and and the modfication did not cause the issue... it was there the whole time...
Also please dont lecture me on how great ABS is... I know its great for some applications... just not plowing my 10 acre yard... I just want to have brakes again...
So you bypass abs controller, bled brakes, and pedal still drops? Sounds like somthing else could be going on? Trouble with master cylinder?
Yes only drops when running... i thought the same thing.. is there some type of safety in the master cylinder that I need to reset... or the small junction box under the MC... I dunno what it does but it has a sensor on it...
Are you 110% sure there's no leaks? Just asking because I've never had a problem bleeding an ABS system without a scan tool. I just did it with a vacuum bleeder, then followed up the traditional pump, hold, / open, close way. But if it ends up being that the ABS unit has an air pocket, I'd just flare up some new lines & couple them to the old ones & be done with it.
You won't get any preaching from me. If I had my way I'd gut my truck of anything that relies on transistors that doesn't control convenience features. IMHO electronics have no place under the hood.
Are you 110% sure there's no leaks? Just asking because I've never had a problem bleeding an ABS system without a scan tool. I just did it with a vacuum bleeder, then followed up the traditional pump, hold, / open, close way. But if it ends up being that the ABS unit has an air pocket, I'd just flare up some new lines & couple them to the old ones & be done with it. You won't get any preaching from me. If I had my way I'd gut my truck of anything that relies on transistors that doesn't control convenience features. IMHO electronics have no place under the hood.
Im sure theres no leaks... but now Im thinking I could have got air in my master cylinder in the beginning and that could be my whole problem... boy would that be dissapointing...
Yeah got to bench bleed them first .... otherwise you'll end up bald/grey a couple decades sooner than normal, if you know what I mean.
I use that as my excuse .... :)
So I got a new Master Cylinder... bled it and put it on... got a little better after a while... bled some more air out of the lines... but still no enough brake pressure to hold the axels from spinning when I put it R.... any ideas guys?
  • 4 weeks later...
Sorry it's late, but if you find some small nails with a head on them, install them where the lines connect to the M/Cyl, you can isolate your problem. The pedal should be hard as a rock, with the nails in there. If not the master is bad, or is airbound. Take out one of the nails, see how the pedal feels. You can isolate the problem, front or rear with this method. Don't over tighten with the nails in or you can damage the flare on the lines.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
