Possible, partial wheel/tire trade......
OK peeps, I've got the itch to install the tires and wheels that I've wanted on my truck sense I bought it.
I have the factory '11 Z-71 18" wheels in immaculate shape with the factory Bridgestone's but I ordered the outlined white letter version. The tires are in immaculate shape as well and the assemblies have been radial force balanced. 14,000 miles on both.
I will partial trade these for some 2007 and 2008 model year Silverado 20" factory wheels only. I'd really prefer the wheels to be in excellent shape but we can possibly work out other deals. I would also contimplate some of these wheels with tires already on them as well but I don't really care about the tires. TPM sensors a must so I may have to remove mine to swap into the 20's and vice versa.
I can meet within 150 miles of Michigan area code 48604, possibly a bit further for the right deal, to facilitate the swap. Shipping these things would most likely cost us both an arm and a leg so local meet up is the only real way, imo.
