Just a couple recent pics
Ah I like traveling but never get to
It's all business, I don't do much personal travel. My moving to MI was to focus primarily on our customers in the midwest, this is a big job so I was sent to assist. Later in the week next week it'll be back to normal- I have a trip to Ohio. :lol:
Damn that's crazy lol
I've only lived in MI about 2 months but I've had this job over 5 years now. The travel isn't much of a novelty anymore since I rarely end up anywhere overly exciting. I was in San Jose for the past week. Far enough north that it doesn't have the awesome weather and it really isn't a touristy area unless you got some weird facination with technology company headquarters. :lol:
I am supposed to go to Saudi Arabia at the end of the month which should be interesting since the only international travel I've done at this point is to Canada which isn't all that different than here. Should be fun but it'll be another long-ish trip and I'll seriously miss bacon. :lol:
I wouldn't go anywhere near that hell hole lol
Bring lots of bacon when u do go though
I wish but it's listed as prohibited items along with booze and porn. Talk about making life for a single guy suck. :lol:
Why in the hell is bacon prohibited what kind of sick country is this
It's got something to do with Islam, they don't eat pork I guess. They also don't let women drive or go out unaccompanied.
i remember an american dad episode that was all about that lmao i would go insane there..
You wouldn't be allowed to do that. :lol:
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 454 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
