2007 GMC Sierra door speaker problems
Hello all,
My name is Andy from Virginia & I have just joined this forum site. I have a 2007 GMC Sierra SLE. recently, my driver door speaker has found a mind of it's own. Sometimes it will be working fine and other days it will not be playing at all. I have also recently discovered that the driver side rear window button on my driver door (where all 4 window buttons are) does not work either. You can raise & lower the window from the rear door button, but like the speaker ... from the front door, sometimes it will work & sometimes it won't.
I guess my first question, should I pop off the panel to see if there is any visable problem ? I sure would like to find the problem there. I would hate to start thinking of the cost involved with replacing the head unit or some far reaching electrical problem !!! I was also thinking that every now & then when I smoke in my truck and crack the window & it's raining, sometimes water will drip and fall onto the whole panel where the 4 window buttons are. I was thinking maybe something shorted out.
Anyone have any advise to share. Anything would be great. Thanks in advance for any replies.
  • 1 month later...
Don't Smoke in Truck! :nonod: could be a short, if your not 100% sure you can figure it out go see the boys at gm!
Good Luck!
  • 1 month later...
this is a comman problem , my 07 did it and i have read about others on this form with same thing going on. my fix was to replace all speakers and add two amps and and a sub, this plugs into the factory head unit. good luck
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
