As easy as pulling a snap ring
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I just may do this one weekend. Thanks for the info guys
Sent from my SGH-I927 using Tapatalk 2
The servo apply's more pressure basically, its mainly for your 1-2, 2-3 shift points, some use it for towing but you can use it for w/e you desire I guess.
Today I wanted to leave my house and I got in an argument with the local Highway Patrol for blocking my driveway. I bit my tongue after asking him to please repark his vehicle twice. I walked inside my house and called the desk sergeant. About 45 seconds after I got off the phone he left in a hurry
so glad I dont live in the city
Sent from my SCH-I535 using Tapatalk 2
Well anywhere you go, the county or state cops can get you
Had the muffler shop custom install my x-piped exhaust! It sounds a whole lot "cleaner" with the cherry bombs than just open headers lol.
I've been under the truck changing cats. Ran into some issues and now waiting for a sawzall to arrive. I pleaded with god. So we will know if I was heard later.
Yea he did. I believe. A sawzall just showed up at my door a few minutes ago
A couple strategic cuts.
Edited by chawkins6789
Quiet. It is loud at WOT. The 6.0 sounded amazing with no muffler but just a touch too loud
Went and bought some shelving rack tonight along with a few bags of fertilizer and water softener salt
Ryan
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
