2012 Silverado to get new Look
Bought my Silverado in Early April. Ordered Wheel hub decals and Recon Cab roof lights (Amber) and found a reputable place to do the install of the lights. Am also adding a Rancho leveling kit. Have the Westin Oval step bars installed and am getting ready to put my Tow mirrors. I found a place that has the Front and Back Bowtie Overlay decals too, Has anybody here put those overlay decals on front, back or both Bowties, and if so, Did it look O.K. when you were done? Thanks for any input. Pat
i used vinyls on my old camaro bowties, they looked good. the front one got chewed up a bit from bugs/rocks after a year so buy an extra.
I used to work at a sign manufacturer, you know like banners and vinyl signs. Well I just went there and got black sign vinyl and laid it over the gold and cut around with an exacto. Never had to replace for almost 2 years now
I have a american flag bowtie on my silverado. It has been on since Nov 2009 and it is holding up well.
Added a carbon fiber overlay to my Camaro also
Here are photos.
I just did that to my Cruze bowties. Have a big roll of carbon fiber vinyl so I figured why not. Looks much better than yellow and very easy to diy.
Sent from my iPhone4S
using Tapatalk
Thanks for the responses, always like hearing how others put stuff on their vehicles. I will post some pics when I am done. Pat
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
