Is my truck an HD?
I posted a topic last week about having an issue with a upper control arms in my Rough Country lift. I put them on and 2 days later took my truck for an alignment. The techs at the alignment shop wouldn't work on it saying that there was excessive play in the UCAs. I took it to another friend of mine who owns a reputable auto shop and the checked it out. He told me that the problem is that the tapered spindle that goes down into the steering knuckle is too small and it just wallows around in the hole of the knuckle. He said that my truck is an HD which is something I never know. There are no badges on it stating this and all the sales paperwork simply stated it as a 1500 series, not 1500 HD. I asked how he could tell and he said by checking the door tag of the truck. It states that the GVWR is 7000LB. He says that if it were 6000LB it would be a regular 1500. Is this so?
Thanks,
Mike
Your V-Max truck will have a higher rating because of that package. Guess that guy soedn't know what he's talking about, The V-Max is not an HD and there was not a 1500HD that year. You have a regular 1500 my friend, with an awesome engine. The rear end will also be beefier thant the regular 1500.
HD specs for that year and CC model :
  • Maximum towing capacity: 13000 lbs.**
  • Maximum payload: 3458 lbs.**
  • Gross weight: 9200 lbs.
  • Curb weight: 5742 lbs.
How many lugs you have? If 6 then regular 1500, the GVWR isn't the deciding factor, my truck has a 7,000 GVWR and is still a regular 1500.
that's typical of the rough country ball joints... a lot of people drill the hole out, but i recommend getting rid of the rough country personally you shouldn't have this many problems already
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
