Another brake light problem question
fingerz2
Hi I'm new to the forum hopefully someone can help me here.
So I have a 99 suburban k1500 4x4 2 years back my break light and turns signals started to act up replaced multi function switch and everything was good. Now I'm here today and my brake lights are not functioning. Let me start by saying my 3rd brake light has never worked in the 6 years I have owned the truck. All my signals are working including hazards. All my running lights are working. Just my brake lights will not function.
I can see the wires to the multi function switch but I can't find anywhere on the internet on which wires to test while depressing the brake as I know they go through there. I can't really get at the brake switch wires to test them with ease anyway so I was hoping there is another point where I can test them. I do not have a brake fuse or relay under the hood there are spots but no connectors. I'm hoping someone can tell me what wires in the multi function harness to test or provide me with another solution.
I should also mention that I parked the vehicle for most of the winter due to a bad fuel pump but as far as I remember the brake lights were working when I parked it. But not the 3rd light as mentioned previously it has never worked.
Without looking at the diagram...
Generally, the brake lights share 1) a signal wire (controlled by the brake light switch), 2) fuse 3) a ground.
First, make sure the fuse is good. Then check for voltage being sent rearward after the brake light switch. If those are both good, check the wiring for integrity of the insulation to make sure it's not shorting out, and clean and tighten the ground for the lights.
Not saying this is your problem, but I replaced the brake light switch on my 1998 with an aftermarket switch because it was the weekend and no dealer was open. Although the switch tested OK on the bench, it did not work when installed. The second one did not work properly either. On Monday I got one from the Chevy dealer and everything was good after the install.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 471 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
