Cigar Smokers???
sw6416
Any cigar smokers around here? What's you favorites? Looking for something new, I smoke one from time to time and enjoy it but find it hard to really find one I really just love and enjoy and can't put down. Any suggestions and why? BTW I will not be smoking any $50 cigars above my pay grade for one smoke. What's good that you enjoy in the $5 -$15 range maybe $20 tops?
I smoke a cigar every Wednesday myself. There's a cool little cigar shop by me that has its own lounge and a good selection, probably about 100 or so different kinds. I try to make a new selection every time i go in there just to try everything. Some of my favorites are Montecristo's, there very smooth and have a really good aftertaste.
+1 to the MonteCristos. The Robusto is my favorite. Lately I've been turned on to Drew Estates cigars. The ACID Extraordinary Larry has been a recent favorite as a full-bodied everyday smoke, and doesn't really drain my wallet. However only light it up if you have some free time. It's a 6 x 60 size so it lasts me well over an hour.
San Cristobal is my favorite (earthy but still a little mild) but I have been giving a lot of attention to Acid Kuba Kuba (very sweet wrapper with a robust filler) lately. You also can't go wrong with a CAO Maduro (very stout) or a Montecristo White label (exceptionally smooth).
I like the baccarat's
Sent from my DROID X2 using Xparent Red Tapatalk 2
I love Macanudo's Gold Label and anything Drew Estate makes even their Acid line of cigars.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
