Bead Blasting a truck frame
I have a bit of surface rust on the frame of my 06. They quoted me $750 with the truck on the frame to bead blast it.
Should I take some precautions on having this done with the truck on the frame?
I am just looking for some general information from people who have had their truck frames done, with the body on the frame still.
I am afraid of damage, or clogging something up
thanks
Just hit it with some por 15 on the rust
Sent from my ADR6400L using Tapatalk 2
Dont get it blasted.. just pick up a couple quarts of POR-15 and brush it on. A buddy of mine did his frame a few years ago.. Still no rusting through. You can order it online.. just google it.
+1
The chassis on these trucks is coated with a wax based anti-corrosive. I think if you try to bead blast it you might end up with quite a mess. You can buy the original coating in a spray can:
http://store.daubert.com/mm5/merchant.mvc?Store_Code=D&Screen=PROD&Category_Code=Noxrust&Product_Code=1786061
I touch it up when I change the oil. It's a good product, you can use it over minor surface rust no problem. Since the orginal coating is not a paint, I think POR 15 might not adhere all that well.
