Lug Nuts
miclri
Recently I ordered a set of snows mounted on steel wheels from the TireRack for my 2003 Sierra. The dealer installed the snows. From the dealer I ordered center caps and threaded lug nuts. I installed the center caps last night.
I used a 7/8" socket to replace the lug nuts. It felt a little loose but so did the 22 mm socket. What is the correct socket size?
And the owners manual specified that the lug nuts should be tightened to 140 ft-lbs. My other cars require something like 90 ft-lbs so the 140 number seemed high. Is it? Would the torque specification be different for the aluminum wheels?
BTW It was a b@#ch getting the lug nuts off. I sheared a Craftsman extension dohickey in the process.
I have used a 7/8" socket since new.  I have removed my tired a bunch of times (different reasons).  No problems yet.
I checked the helms manual and cant find anything definite except the wheel nuts are M14 X 1.5 (The M is for metric)
But it also states the rim is a 16x6.5 in the manual which is untrue it is a 16x7
the 140 ft.lbs. should be correct. Trucks get more of a Torque spec then cars. I dont know if it would be different for aluminum wheels or not.
Yes, Ryan suggested the 7/8 to me and it works fine.  Also, the local Firestone shop was concerned with the 140, but I told them that was the spec.  I've had them off and on once or twice myself with no problems.
I think the stock steel rims are 16x6.5 and the optional aliminum rims are 16x7.  I think the HD rims are 6.5's though for both steel and aluminum.
Shaners the helms manual has info for each type of tire (steel, chrome, and alum) they each state 16 x 6.5 which is another error i have found
Thanks for all the info. I was concerned that at 140 ft-lbs I would round-off the lug nuts with the 7/8" socket.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
