Tailgate lock
Where is the best place to get a tailgate handle with the lock built in? for a GMT-900
Would need to be shipped to canada, Thanks!
Ebay, look for a chevy dealer in the US and get it shipped... thats what I did. its costly up here
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
