Want to hard wire Garmin GPS
Just bought a Garmin gps and I want to mount it using the vent holder also that I got, but I don't want to have it plugged in using the cig lighter plug. Where can i get the power from that doesn't involve major re-wiring and taring the whole dash apart to find 12V.
This would have been so much easier if I had my 88 FSC.
Sent from my BlackBerry 9300 using Pik-n-Pek Tapatalk
I hard wired in some under dash LED's on my '07 and used an "add a fuse" in the fuse panel on the driver's side of the dash next to the door. The jumper keeps the fuse for the fuse that you tap and adds an inline fuse for whatever you add. They cost less than ten bucks at most car parts places. If you're using the vent next to the door you'll be real close...I've heard that there is a different, more complex option in a different post, but I'm electronically challenged and this was an easy upgrade for me. I'd like to do the same for my Tom Tom, but the cigarette lighter cord apparently has an antenna for the traffic updates and I hesitate to splice it as I'm not sure if it will put the whammy on traffic updates. I believe that I used a Cooper Bussmann ATM fuse tap.
Montyss, I hate to sell what you sold me on, but it seems that the power port you linked would eliminate splicing the accessory or even an aftermarket lighter socket. Also negates finding a switched vs unswitched fuse port to jump onto. So not only can I use this to hide my Tom Tom cable, but it also keeps the traffic updates flowing and keeps the device still portable between vehicles...thank you neighbor to the north. :thumbs:
