New rear shocks after 3" blk install
Just wondering what I should use for a rear shock now since I've put 3" blks on. Ive noticed a change in ride so I think a better upgrade is needed and I also want a shock that will be a bit larger since I've extended the stock ones now. Any ideas???
most people are likely to recommend bilsteins, they have options for taller than stock vehicles. or skyjacker, rancho, rough country, bds, any of them make shocks for taller applications
I'm also looking for a smoother ride and hoping to achieve this with better shocks.
If you want to improve the ride, Bilstein's are the way to go.
Any idea on which model of bilsteins to go with? Just want to make sure they fit the truck and with the extra lift
Look at the bilstein site. They only offer 2 rear shocks. 1 for nonlifted and 1 for yours.
Sent from my iPod touch using Tapatalk
Should an extension be used with 2" blocks?
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
