Leveling Kit
Going to be installing my Rough Country Leveling kit tomorrow, any advice to help me get it done a little quicker? When I try to get the truck back into torque specs, what should I put them to? (Don't really know if I worded that correctly!)
Did anyone else use this video? At the 2:40 mark the bolt looks awful close to the rod above it, does that geometry change once you are finished? Does anyone know the torque specs?
Thanks for posting that video!
I am unsure of the torque specs from the factory.
This is all from my Zone 2'' Level Kit instructions:
  1. All 7/16'' bolts - 45 ft lbs.
  2. Upper Strut Mount - 40 ft. lbs.
  3. Upper Ball Joint - 40 ft lbs.
  4. Steering Knuckle Factory nut - 44 ft. lbs.
  5. Sway bar bushings should be tightened until they start to swell.
I know they are different leveling kits, but did you install yours like the video, or did you follow the instructions? The instructions given seem like there is a lot more 'work' than the video shows.
40lbs sounds in the right ballpark. I think i did all mine to 37 lbs if the RC instructions say that too. I also did mine exactly as the video shows above. The toughest part is getting the spacer in. You may need to pry the shock up a bit as the video shows, but it should be fairly easy. An extra person to help never hurts either. Biggest thing is to re-torque everything after the first 500 miles, especially the spacer bolts. Mine did need some tightening. Doesn't hurt to check every 1,000 miles after that too. ...and the realignment...don't forget that either.
I installed mine by that video. Its fairly straight forward. Don't undo any of the upper stuff. No need. Just follow that video and your golden
Thanks everyone. That seems really easy compared to the instructions. I am going to do it that way so it will be easier and I can get done quicker!
Well it is on and sitting next to my brothers truck, 2011 Extended Cab Z71 4x4 where mine is a 2009 Crew Cab LS 4x4, there is a noticeable difference. He is going to be ordering the kit and we will do his truck soon. Can't wait, never thought I'd say this, to buy tires that will look more appropriate.
I will get some pics once my camera gets back from Nikon. Hopefully soon cause my boy's first birthday is a week from today! Once I get it back I will take some pics and load them up. Now I need to decide what rims and tires I want to buy next spring.
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 449 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
