Guys with factory 20's, whats the space that came with it
Chris
I changed to 20's and I'm running a 275/55R20. I havent had a spare in 4 years. I am going to get a junkyard winch, tools and wheel just need to know what tire to get.
Pretty sure ALL the 1500's come wit ha 17" wheel size spare tire. Would be nice to have a matching spare and wheel though. Seems that no matter what tire wheel combination is on the truck, you are stuck wit ha Good Year and 17" steel wheel.
I had a 16" spare with a 235/75R16. But I have chaned tired size and will most likey go to a 17" because i want to do the 05+ front brakes. I can get a steel wheel cheap the tire size is what i dont know
My buddies 05 truck came with 245/70/17 spare tire. Find a 17 inch tire that is about the same circumferance as your 20 in tire. Keep the width to a max of 265.
not to jack the thread but i have 285's and a 265 spare. i have had mixed answers on whether i can use it or not. anyone know?
A 265/70-17 is only about 1/4" smaller in diameter than a 275/55-20. You should be able to use it with no problem, as the ABS/traction control/stabilitrac circuitry will absorb that small a difference in rotational speed. When it comes to the differential, however, it is best to use the spare on the front when you have that choice.
Depends on what your 285 tire's aspect ratio is. 285/?/?
Your regular tires are just over an inch bigger than the spare. I know a few people who run 285's and carry a 275 or 285 spare in the bed. I've ran spares with about that much difference with no problems. It's up to you.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
