Oil pressure issues '04 5.3L
Hey guys just about a week and a half ago the oil pressure on my Tahoe shot up to the 80 mark when RPMs are over 1500. It never used to go this high even when at 4k while passing someone on our two lane highway. Now it sits at 65 lbs when below 1500 and anywhere from 75-80 from 1500 on up. Is this a gauge cluster issue or a motor problem? Any help would be great.
kind of sounds like the gauge cluster stepper motor
thanks for the input guys! I'll be in denver next week so I may run it by somewhere that can check it for me. I need a new Cluster anyway so maybe it's time to change it out.
i put an HD cluster in mine when it went out and then got the SS overlay
Where did you get your cluster from? I see there are lots of places just curious as to who recommends who.
I got the cluster itself from a salvage yard, i got a standard 2500 HD gauge from a 6.0 4 speed . the one i used is pickup salvage. google them they ship. but they are local to me. and i got the overlay from gmgaugeguy.com. he is a member on silveradoss.com. it was about $100. I think $115 after shipping
Thanks man I am going to call him up and get this thing sent in for repair. I think im going to do the White LED upgrade while it's there since these things are notorious for the back lights going out also.
He recommended the light blue to me. He said it makes the needles pop. I was thinking white myself. I spent a while on the phone with him. But that was with the SS face
Could be a sending unit
+1
Check the sending unit first. Going to be cheaper than putting a cluster in it first, then change the sending unit.
Well my cluster has other issues too so the 160 plus shipping isn't a bad start anyway. And worse case I'll move to the sending unit next. Thanks for all the help gents!!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
