OGM1/iGo Primo "Altitude" fix & "Accept" override
Yeah, so just reading my previous post and I see where I don't make sense.
So here is an effort to clarify what I am really trying to ask lol.
Is there a way to program the unit to auto boot the navigation at vehicle start up? Even if it was a delayed auto boot and not necessarily to the nav screen that would be fine by me. An auto boot or delayed auto boot coupled with the anti-nag screen program will allow me mid commute to hit the nav button and get the map up on the screen on demand. As of now in the case of needing the map mid-commute requires a wait period that seems forever at freeway speeds.
I knew you'd see that old "installer" Dutton :jester: on that list! Funny stuff! If you ever see his "C*ck in a subwoofer box" TV ad anywhere online (done years before Justin Timberlake and Andy Samberg), send it to me...
Here's the scoop on the auto start - I know this is one of the most talked-about tweaks there is for iGo Primo, but I'm walking a very fine line between satisfying everyone by releasing what I know, and bringing the wrath of my largest supplier down on my head for doing so.
I know it's unstable, and I haven't been able to get it to work right. I know there are LOTS of guys smarter than me out here that MAY be able to get it working, but I doubt that it will be perfect without input from the factory guys, and they've already told me that they aren't going to help because the system was not designed to function that way and will cause issues for the vast majority of users.
I'm not saying that if I can't fix it, then nobody can, but the dilemma I'm in is that If I tell everyone to tweak their systems and they start blowing up, then Advent will hear about it and I'll get my a$$ handed to me.
I think this may be one tweak that just gets handled in another way...
But, Walt. But, Walt...
There's already an option to auto-start iGo. But if you switch to any other screen after it auto-starts, the OGM1 will revert back to the GPS screen after a few seconds.
If the software/firmware would allow you to select whether or not to automatically switch back to the GPS screen (after the GPS has already started), isn't this what folks are requesting?
But, I'd still buy another one just as it is!
Ahh ha ha ha! That ad had to be mid 90's if I remember right! If I find it I'll send it to you. I bet Albert could get a hold of it for me.
As to you walking the tight rope with the vendors ... Enough said and understood. Gotta keep those relationships clean. For now, I'm trying to get into the habit of hitting the nav button when I start my truck to begin the boot process and just going right back to my original source but for some reason I usually end up just sitting there staring at the screen until it fully boots.
True, but the only issue with this is that it ALWAYS reverts to and displays the navi - it doesn't keep it going in the background so that you can have your A/V source display THEN switch to the navi that's already running when you switch to the navi source.
Personally, I'd like to have my radio display on when I'm listening to radio, USB when on USB etc., then go to navi and have it already queued up. I think this is the way most guys would want to control it.
My Ideas,
I am in and out of my Sierra 5-10 times a day and I hate having to wait for the OGM1 to boot up every time. I tried leaving the key in the accessory position and having the system up and running while parked but as soon as I turn the key to START the system powers down then boots up again so that didn't work.
What I am thinking of is to power the system full time, ie. not thru the keyed power and have a separate push on/push off switch to turn it off at my leisure. That way I can leave the sytem booted up and running so that when I jump in the truck it is already to go.
One thing that I have noticed is that if you leave the key on and turn the unit off with the ON/OFF, VOLUME switch, the CPU keeps running and will instantly boot up when the ON/OFF switch is turned back on.
So with my suggested rewire of the input power, I could turn the screen off when I park the truck using the ON/Off switch and leave the CPU in what essentially would be standby and in a reduced power consumption mode. When I jump back in to use it again, it would just be a push of the ON/OFF switch and the system would instantly be ready to go. When I leave the truck for an extended period such as overnight I could completely power it down to save battery by turning off the power via the PushON/PushOff switch.
The benifits of this would be the time saving of waiting for the system to boot up every time I get into the truck and not having the wear and tear of the CPU having to boot up 5-10 time a day. The detriments other than a bunch of wiring are that I now would have to turn the display off and then back on again each time I use the truck and would have to remember to turn the power source off when leaving it for an extended period of time to save battery drain.
Any ideas or suggestions for this? Have I missed anything?
Thinking outside the box, I like it!
What my X5 does with the factory BMW nav is start the boot process as soon as I hit the unlock button on the key fob. This allows for the time it takes me to get in the vehicle, actually start it, get my belt on, and reverse out of the garage, to finish the boot process. BMW calls it a 'wake-up' process. Likewise the vehicle has to sit long enough to go into 'sleep' mode.
Now I don't know all the in's and out's of either my BMW or my GMC but doesn't our trucks have a 'sleep' mode as well? Like if I leave my dome lights or headlights or anything on for an extended amount of time it will shut off to save battery?
Maybe we could rig our units to work on that theory?!
My Ideas,
You missed the most important thing - the OGM1 doesn't have an accessory power lead. It already is wired to a constant power source (and it's the ONLY power that goes to the OGM1).
It takes it's turn on (ACC) signal from data to begin the bootup process. There is no way that I'm aware of to trick the unit into staying on - not only because of the lack of an ACC power feed, but also the RAP circuit that shuts off the deck after 20 minutes.
Even if you wanted to use the red ACC lead on the back of the deck (used for bench testing only) and run it to an ACC source, you're almost begging for trouble, because one of two things will happen: Depending on the circuit you use, you will get trouble codes for the additional draw that the BCM is detecting from the deck (best scenario), or the BCM will recognize the draw from the deck and the BCM will flag the codes, then stay on itself, accelerating the discharge of the battery (worst case).
If it were me, I would not risk trying this method unless you didn't need to use your truck for anything mission-critical, like driving... :)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
