In need of 2.5 inches off front lift
I have an 08 currently with the ccm 2.5. The ride sucks. So i am wanting a different better way to acheive that amount of lift. Whay would b the best way?
I used the Rancho Quicklift. It isn't 2.5", but it is a really good product IMO. I don't see the point in putting an extension on a factory shock as it would just preload the shocks which can cause poor ride quality. But a lot of people use them and have no complaints.
Yes but i need 2.5 of lift. I have 295 55 20trail graps that wont fit with less lift. Is there a combo of spacers and level struts that i can do. I have rc 2" level blocks that i can use.
You could body lift it. Just a suggestion.
I would suggest this also. I really don't see a different set of spacers helping with ride quality.
What about the Bilstein 5100 shocks? I think they go to 2.5", unless you aren't looking to spend that kind of money.
Not a good idea to stack leveling systems....body lift or suspension lift is the only way to fit those tires if you remove the leveling kit.
get bilsteins and add a .5 spacer with it. thats what i did, and it rides great.
  • 4 months later...
What kind of spacer is .5 inch spacer. My bilsteins arrived today and am going to be installing asap. If I can't find a small spacer err I will use my rc and just put the shocks on the lowest or second setting
i have a 2" rough country leveling kit, plus a 1.5 zone body lift and would have cleared my 295s no problem if it weren't for the offset of my wheel which caused me to do some trimming
