Gray 08 Posted August 29, 2012 Posted August 29, 2012 Installed my 2" leveling kit. Anyone have the specs as to what I should have the shop set the alignment. Custom or factory spec as I want the least rolling rolling resistance and the best wear on everything.
latreille89 Posted August 30, 2012 Posted August 30, 2012 factory specs Can't align to factory specs when you've chance the geometry of the front suspension. Just have them do an alignment like they would on a 88 buick.. Where there are no factory specs
Gray 08 Posted August 30, 2012 Author Posted August 30, 2012 The toe and caster were set wrong from the factory and I got that corrected.
ruggedlife Posted August 30, 2012 Posted August 30, 2012 well hot damn mines set to factory specs rides perfect steers perfect and my tires do not chop at all and yes i did watch it get done and yes i do know the shop that did it and the mechanic that did it.
latreille89 Posted August 30, 2012 Posted August 30, 2012 When the dealer did mine after the level, they said you can't align to factory specs. And they showed me where they aligned it to compared to factory
Gray 08 Posted September 3, 2012 Author Posted September 3, 2012 ^^ The dealership told me they could align after the level but were unsure of what factory spec was. I went to a shop that gets things done with no problem. Drives perfect better than off the lot perfect.
