Abs and Brake lights come on while driving.
Hey everyone, for the last year and a half or so the abs and brake lights on my 99 silverado will come on after driving it a little while. Before they would not come on for a week and then some weeks they light up all the time which is why i never did anything about it but now it lights up pretty much everytime I drive it. I had my buddy scan it and the code c0265. I googled the code and found out it has something to do with a relay circuit and loss of communication. I'm wondering what the code means for sure and if anyone else has had the same problem and what can be done to fix it.
Thanks,
Nick.
Probably a brake light switch. Easy fix. Cheap part. Its the plug that is connected to the brake pedal.
This is actually a common problem from what I've discovered. Do a search and you'll get tons of information. The most common source is a bad ground to the module controller. It's grounded in the inside of the frame near the driver-side door. Mine came on last night when hitting a bump in the road.
I looked at the link you gave me above and I still think the module is bad inside. I did some research and found out about module master that rebuilds abs modules for 150 bucks. Has anyone ever used them before? It seems like a pretty good deal compared to spending close to 1,000 bucks for a new module. Only problem I'm gonna have is getting the module off the pump. I live in Iowa and the torx bolts look to be rusted pretty good. But what can you expect from a 99 thats seen winter roads every year. Looks like I might have to undo the brake lines and take the whole pump off the frame to get the module separated from the pump. Anyone else had this tough of problem getting the module off?
Thumbs up on ModuleMasters.
Just went through this on mine. 13 years and 163k miles before the module completely failed. I took it to the local dealer for diagnostics - not only was the module failing diagnostics, but so was the pump. On went the ebay special, but its module was dead too! So, off to Modulemasters it went. Less than a week later, I had it back. Got it installed a day or 2 later and no more brake lights. 5 year warranty on the rebuild and I still have the original module just in case.
would this cause like a pulsing feel on the pedal just before u stop, cause mine is doin that, i havent had it scanned yet but the abs light came on almost once a day for like two weeks then hasnt been back since but the pedal thing bugs me its like hitting a patch of ice just as u come to a complete stop thankfully i dont live in the city so not too many short stops. o i have a 2004 gmc sierra 5.3 4x4 crew 105k mi
I've never had the pedal pulsate on my truck before stop. I think in time I will take mine to the dealer and have them take a closer look to tell me exactly what is wrong. My lights have been coming on for at least a year and a half but now they come on everytime I drive the truck.
This may be the low speed ABS activation that has plagued Chevy's and GM's. The ABS will activate while you are braking and get down to 5 mph or so. It has to do with corrosion building up under the Wheel Speed Sensors on the front wheel hubs, causing a bad signal to the ABS system.
There are a number of posts on this, but basically, after checking the front wheel speed sensors, you can remove, clean the mounting surface and re-install.
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
