Transmission problem in reverse
I have an '07 Sierra 4wd and the tranny started acting up this week. When I put it in reverse the truck will start to move backwards but if I give it some gas the tranny seems to slip - the truck feels like its in neutral and the rpms go nuts. this only happens intermittently - twice in the last couple of weeks. Anyone else have this happen? Wanted to get some advice before I take it in to the mechanic.
Kinda like yours but what I did was put it in reverse and immediately stomped the gas
And the rpms shot up then it finally engaged hard and off I went. Was pissed so probably will never do that again. Oh and the engagement took less than 2 seconds if not sooner since it was almost automatic but like before had already put my foot into it.
Check to see if you have engine braking in manual 1st. That can really help narrow down where the problem is. Most likely the low/reverse clutch is shot and you need a rebuild but there are also a few other things that could cause it.
