Service Transmission Now Unable to Shift Soon, I got this warning after starting the car, I have no problem, no sound, no overheating, everything is normal.
If you haven't already please signup for the giveaway for a chance to win a set of Bilstein 5100's, sponsored by Scovel Motorsports. Here is a direct link to sign up.
https://docs.google.com/forms/d/e/1FAIpQLSdL9Nnt7ekgPBmMeh3sxJpkXQQg2T6i7D9VxN0BI0k-Z6CzwA/viewform?usp=sharing&ouid=113910338513955913118
My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
The oil filter has NOTHING To do with oil leak. GM sources parts from 1,000's of vendors and as with anything mass produced, flaws are unavoidable.
Putting a larger oil filter will do nothing but satisfy emotions. The OEM filter is designed for the engine and perfectly capable of handling the demands on the engine. Oversize oil filter could result in reduced flow and overall lower oil pressure.
