Banks Monster exhaust system?
Has anyone had the banks power exhaust for the 5.3l? just found it and now am interested. i know they really do a great job on diesel but just not sure about the gas.
Any help or info would be great thanks
just from the video on their website it sounds good. I wish they had a video clip of the 5.3 though, i'm always worried the 6.0 or 6.2 will sounds good but the 5.3 wont. I'm a dual out kinda person, so i would go with the dual and change the tips out as i'm not a huge fan of the quad tips that they have on the dual system for GM trucks.
I've got the monster exhaust on my 5.3L and love it! It's got a really deep throaty sound when you get on it but is quiet going down the highway. There is very minimal drone inside the cab and is really only noticeable when it's in 4 cylinder mode. I can take a couple of pictures this weekend and post them if you'd like?
Thanks Jason that would be great .
I agree with you brandon not a big fan of the quad tips but I think I willgo with the side exit instead
I've got the side exit too. I ordered directly from Banks and got it for like $415 a year and a half ago. The sales rep said the quad tips are not selling well. The sound is very similar to the 6.2L and 6.0L they have on their website. I have had corsa, borla, flowmaster, and magna flow on my previous vehicles and this is my favorite exhaust so far. It's nice to not always have it being loud and droning. Plus for the price it can't be beat!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
