Speaker Replacement help
plunk77
Ok so I am looking to replace the stock speakers in my truck. I'll admit that I really have no idea what I'm talking about when it comes to electronics/car audio. I'm more of a mechanincal person. I think I'll be able to do the install myself but as far as what to put in there I have no idea. So here's my situation:
I love my stock radio. It has XM and the USB port that i play my ipod through. So i really don't want to replace that,
99% of the time the music coming out of my radio is country, so I don't need an incredible amount of bass.
The reason I even began to think about this was because there is a vibration coming out of my back speakers that sounds as if they are blown. I read on here that that vibration is probably the factory insulation, so while I'm changing out the speakers I'll put some Dynamax insulation in there (again, I don't know what I'm talking about, just read about it and saw i could buy it through Crutchfield)
So i guess my question is what speakers would work best for me? I don't want to break the bank I just want a better sound and to get rid of that stupid vibration.
I just replaced all 4 door speakers with Polk DB651s speakers. I am extremely pleased with them! Although I also got a small amp for them. I still have the factory stereo. I had Infinity Reference speakers in a previous truck and they were also great speakers. But the Polks are the best I've had so far.
I hope I'm not hijacking the thread and that my question will also be useful to Plunk as well...
I am looking to replace my speakers (Bose system) and have been reading around on which speakers to use to replace mine (my front passenger is doing the same thing as Plunk's). I have read that the stock Bose HU is not powerful enough to run aftermarket speakers and that they will actually sound worse than the stock Bose speakers. Is this true? I would be getting 2 ohm speakers for the front and 4 ohm for the rear but I am going to pull the panels off to confirm before I order.
So, if I were to get aftermarket speakers to replace my factory ones, will the HU have enough power to run them and they still sound good? I'm not expecting awesome $2000 stereo sound, just something better that sounds good.
  • 3 weeks later...
I guess my biggest question is is it necessary to get an amp if i just want to replace the speakers?
Do you have the bose system or just the base?
Either way, I would start with just replacing the speakers and see how you like it. There is already an AMP in your system technically whether it be in the factory head unit and in a separate amp (Bose systems) so get yourself some good aftermarket speakers that do not have a huge power demand and you will probably be ok. Rule of thumb is the more they cost they beefier the components so the more power they will need. So spend under $100 on a name brand (polk, fosgate, alpine, etc) and you should be ok with the oem amps. If you decide the are underpowered then you can always add an amp afterwards.
If you are just doing the back speakers, then you have coaxial types which are the most common as opposed to the fronts which are component (tweeter and woofer are separate). If you are doing the fronts then you will have to consider weather to replace both the tweeter and the woofer with a similar component setup (more work) or a simple coax (less work, less power demand, not as "ideal" sound setup as component but can still sound good).
Ernie
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
