1995 GMC Yukon Idle Surge When Warm
Mule
1995 GMC Yukon (non-Vortec, OBD1, TBI), ongoing for about a year, after truck was taken out of storage for 13 months:
Always smells a little rich.
Cold start – Long cranking, smooth idle. Smells very rich.
Warm start - no codes, no SES light, warm start (30 minutes off after full hot), short cranking, initial smooth idle; surging idle starts after 20 seconds. Feels like stalling, then catches itself and goes up to 800 RPM, then drops and repeats. Smooth idle and ride after about 1 minute. Smells rich/flooded. Not as bad in the summer, but very bad in cool weather.
Overall, it seems like something heats up, cools off, but not all the way cold, then either malfunctions or gives a bad reading to the computer which creates the surging. After a minute, it either warms up enough to stop malfunctioning or giving the computer bad info.
I have been to nine shops and they can all duplicate the symptoms, but can not track the source.
Thank you for any help!
No change after any of these fixes:
03 Jan 2012
Replace Coolant Temp Sensor
Replace coolant temp sensor connector
11 Jan 2012
PCV replace
12 Jan 2012
Replace Fuel pressure regulator
Replace driver’s side (left) fuel injector; it was dripping
14 Jan 2012
Clean air filter
24 Jan 2012
Replace Dist cap and rotor
Replace ignition coil
Replace Ignition Control Module
Tighten Idler Air Control Motor
31 Jan 2012
Replace IAC and pigtail
Replace O2 sensor
08 Feb 2012
Replace fuel pump
Replace fuel pump sending unit module
05 March 12
Replace fuel filter
08 March 12
Replace Spark Plugs (AC Delco Rapid Fire #1)
Replace Spark plug wires and heat shields
10 April 2012
Removed Jet chip to aid diagnostics
Replace Throttle Position Sensor
Replace PCV hose
Replace elbow on rear of TBI crankcase breather hose
25 April 2012
Replace MAP Sensor AC Delco
01 June 2012
Replace vacuum hose from A/C accumulator to heater control valve.
02 July 2012
Replaced TBI plastic ring and rear breather vent hose
Sea Foam spray into TBI
30 Nov 2012
Re-install Jet chip
Replace EGR valve
stored for 13 mos look close for a mouse in the house, had at least 5 newer chevys with crazy issues only to find chewed wires to ecm/pcm. then check with motor warm hold just over idle and spray non flameable brake clean around intake to valve cover area and base of TBI. TBI to intake gasket check/replace and if any flutter off idle w spray pull intake. if i remember and this is 5.0 5.7 they had aluminum intakes. they will warp and distort gasket. if you pull intake inspect around ports for cracks or crushed gasket. DO NOT USE AIR TOOLS TO CLEAN OLD GASKET OR HEADS!. air tools will destroy trueness of both surfaces. clean with good carb cleaner and hand scrap hard stuff with razor blade and hand sand 80 plus of higher depending on how bad they are. while off use straight edge (roofers square) lay across ports, shape should be true or damm close. also 5.7 i have seen a few break a head bolt so pull valve covers and toqure to spec to see if one is weak. other than that there should be a port in front of TBI unit maks sure no carbon, and also check vac to brake boster, boster could be bleeding off vac and make motor surge, hope it helps
From the top:
1. No signs of any rodent/bug/animal contact. Storage was a very clean facility with animal control.
2. Did the spray for vacuum leaks a few times over the last few months with no change in idle. TBI gasket was replaced last week.
3. Not at the point yet to start pulling the intake off, yet.
4. Checked the brake booster vacuum line and it is good. New brake booster 4 months ago for a different reason, but no change in this problem.
I do feel that it is a vacuum leak I am chasing, though.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
