2011 silverado bad heater core
So I get in my truck this morning to go to work after I warmed it up some. The interior smelled of antifreeze. As I drove to work the windows kept getting progressively more foggy and the defroster wouldn’t do anything. I had to keep wiping the window in order to see. I ended up at the dealer and they called me that I have a bad heater core-6 hr job. Good thing I’m under warranty but on a 2011 truck with 15k miles-WTF? Anyone else have this problem? I hope it’s not a sign of things to come. Last week I had her in the dealer for a bad tire sensor and now this. I hope I didn’t get a lemon! I had a 03 Tahoe once that always had something wrong with it. I swore I’d never get another chevy but I also didn’t want to pay 50k for a Ford or Toyota. Got mine for 32k. It’s a 4x4 Z71 Crew. Thanks for any input……
Discouraging I'm sure, but you may have just hit a bad part. I had a power steering pump go bad on my last truck during warranty.
Maybe it was just a "BAD" connection issue, and not an actual failing heater core???
A GM tech would get paid to "R&R" a heater core if this was the case- Just to get at the source of the problem.
When you pick up your truck (after the reapir is completed), check & see if a GM "warrantied part" is build out on the repair order. :happysad:
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 876 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
