Dash lights remain ON, why?
Dag19
Piece of junk?! haha come on now!! Hmmm alright, I sure hope someone else has had this issue and can come up with a solution. It bugs me! I know it, electrical goods are expensive. I hope I don't have to go that route.
you dont want to throw a BCM at the truck without having it diagnosed properly,,,,,you cant return it if its not the problem,,,also it has to be programmed by a shop that has GM service information and a tech2 scanner ,,,,
get an Alldata account and start diagnosing it $27/yr
or take it in ,i think this maybe above your comfort/skill level,
good luck
it may just need a reprogram,who knows
  • 5 years later...
Chevy 2500 05 . My dash and radio stayed on after key was out and I got out. I opened passenger door and it went off.
Door switch
unplug your wiper motor and see if the lights go off . it took me days to find this problem and it turned out to be the wiper motor had a shorted diode and was back feeding keeping the dash lights on
  • 1 month later...
I know this is old but for others who might also experience this... I am having the exact same issue. Truck was at shop for waterpump. Got a call it was done. Got there, batteries are dead. Both new Optima red tops. Finally get it home and the dash lights issue reamerges. I'm thinking its draining the batteries and start looking closer. Pulled codes and got this, B2615-passenger compartment dimming #2 circuit malfunction. So I tried opening the passenger door also as someone else suggested and it worked. The dash lights cancelled out. Not a solution to a fix, but a lead.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 463 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
