TOO FUNNY!!!
Bad Bowtie2
Yea I posted on another forum when I saw it saying I have to have it
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Not available to California residents unfortunately
Banned only in Califorinia ....California residents are OK. :thumbs:
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
