Which tire for a 22" wheel
Chris
I'm going to go with a 22x9 Trailblazer SS replica. I run 275/55R20's right now. Current wheels are 20x8.5 with a +22 offset.
The new wheels will be 22x9 with a +22 offset.
I have a level. And I want to keep approximately the same height tire. I have looked into a 285/45R22 and a 305/40R22. Can I run the 305 on this wheel without rubbing? I want to get more rubber on the ground because I have some traction issues.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
The 285 will fit. It is leveled. And that is the smallest I'll go. But old love to have the 305
The 285 will look great on the 9" wheel. I run 285/45/22's on mine an it looks perfect. The sidewall on the 305 will bulge a little.
