Well its that time again. Need advice.
STINSAN3
So, I need some new tires. My Cooper Zeon LTZ's are about wore out. They have been pretty good tires. I'm thinking about getting a different tire, but don't know for sure if I wanna do that or not.
I'm thinking about getting the Toyo Open Country AT 2, Cooper Discovery HT plus (which are the cheapest, but had a lot of good reviews), Nitto Terra Grapplers or Cooper Zeon LTZ's again.
Just kinda hard to find a wide variety of tires in the 305/50/20 range.
Any thoughts and suggestions would be greatly appreciated.
I have heard really good things about the Cooper Discoverer HT. Reasonably priced tire that performs well, is quiet, comfortable, and lasts long. I will be getting a set when my current tires wear out.
I'm going with Falken Wildpeaks once these stupid Goodyears are done. There's a half inch gash I patched that's getting bigger, so it may be soon. I don't know if they're your style, but the reviews are what convinced me.
I have the HT Plus. I love them. But I tow and dont go off road. A great handling tire and amazing in rain. They are quiet, I have put 20k on them in the year I have had them
I'd probably go with the new Toyo AT2...they look awesome. I kinda wish I would have chose them over my Cooper AT3's.....don't get me wrong....I've been very happy with the AT3's...I just think the Toyos look a little more aggressive. That being said, if you spend all of your time on the highway, then the Cooper HT would be a good choice....and be cheaper too.
I'm thinking about getting those, how good are they holding up? I guess you have no idea how good they do in the snow, since you live in Cali.
I think I'm gonna get the Toyo's or the HT Plus from Cooper, I don't do much off road driving but, when I do I like to have that traction. Especially in the snow, since we got that big snow storm from yesterday. I like how the Toyo's look agressive.
I thought about doing 285/60/20. But where I got a BB Tune, would I have to take the BB tune out & send em to get it retuned or how does that work. Bc my speed wouldn't be accurate.
I have terra grapplers on mine and love them but thinking about upgrading in size to 305's. have 275's right now. Zeon LTZ's are on my list. Can't decide if I should switch or not
Hard to believe that the Nitto's weigh the less out of the four. I think I have came down to the HT Plus & the Toyo AT2
Can I run a 305/55/20, without any trimming or add a BL?
One of my friends told me to do that if I could.
With a body lift, (I assume you have a leveling kit already) the 305/55/20 should fit. Are your rims +18mm offset?
Yeah man, I'm pretty sure they are. Also, I do have a 2" Leveling Kit
With a body lift, (and your leveling kit) they should work. If you end up having to trim, it would just be a little plastic.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
