Toyo AT II 285/75/18 will they fit?
Jayson.Medic
Ok so i have an 09 cc 2wd with a RC 2.5 leveling/lift. i currently have stock z71 rims and tires (265/65/18 birdgestone). will these fit w/o extreme trimming or rubbing? according to toyo website they are 34.8 tall by 11.3 wide. If you have pics with similar tires this would be great.
Some times you can get lucky and just have to trim a little but thats a big tire.. What about 285 '70' 18
He had a nnbs he can't go bigger than 33 with a level kit. Even then he will most likely rub a little at full lock and on steep driveways
Ok so what about 275/70/18 or 285/65/18 toyo at 2?
Either of those will work much better. Many guys run those with a leveling kit and stock rims...and don't have any issues. As a general rule, the 275's will be cheaper, but the 285's will look better.
how much bigger is a 75 over a 70 or 65
If you referring to the 285/ /r18 the 65 is 32.5", the 70 is 33.7", and the 75 is 34.8" I believe
Sent from my SGH-I927 using Tapatalk 2
What size tire are you looking at? The ratio will change depending on wheel width and tire width. You need to be more specific with your question.
Yeah we need more info about your question. The aspect ratio (the second number in a metric tire size, and the one you're asking about) determines the height of the sidewall, in relationship to the width. However, the width (first number in a metric tire size), as well as the rim diameter (the last number), all help to determine the overall 'size' of the tire.
