Traction control
traction control light came on today. 37 degrees and perfectly dry roads. Truck has 40,000/2010 silverado/4 wheel drive/5.3.
Is this a normal thing for the mileage. If the traction control requires service; what is done? Thanks in advance to all
Read the owners manual for this vehicle.
My "trac control" indicator lights up anytime a rear wheel looses traction on my C1500, then goes back off when the rear "G80" unit locks.
I read the manual..mine also lights up when losing traction...this stays on all the time now and sends a message across the dash that service is needed for traction control
There is a fault with the system. There is no "service" to be done, simply repairing or replacing parts is what that message indicates.
Ok, sorry. I missed the part about a message being displayed saying "SERVICE is needed for traction control system".
Good luck.... :happysad:
Gets better....read the manual after driving to work...about 6 miles...traction light and message still on dash. Manual said to turn the wheel fully to 9 o'clock and then to 3 o'clock and then shut down...start up after 15 seconds or 15 minutes but I let it sit for 8 hours. Started it up and drove the 6 miles home and no traction light on or message...like it never happened...will the codes still be there or was there a glitch that was cleared by doing the manual directions. ?
On a side note...I hate all this technology crap. Anything more than a PCV valve is a waste. My 2 cents.
terzmo,
As “govtech4” has mentioned, the code should be stored. I would still encourage you to consult with a certified technician for an inspection.
If you need assistance locating a technician near you, please PM me your zip code for a listing.
Louis (assisting Tricia)
GM Customer Service
after getting the lights to go out and everything looked good,drove it a few miles..left turn..lights/message back on...took it to the dealer and after 2 hours of troubleshooting wires,as they said, found out a sensor is intermittent and will cost 400 plus to fix....4000 miles past the bumper to bumper warranty.
terzmo,
GM Customer Service
I guess you missed my last post.
terzmo,
GM Customer Service
are they gonna goodwill the repair????
no goodwill...whatever that is....I crossed the ine at 36K so I'm stuck with it, they did give me 30 dollars off for being a retired vet..lol
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
