drop in a 6 oh :D
Sent while drinkin' a cold one...
Dont give away my secrets
Ew no I'd rather turbo my 5.3 than run a 6.0
sent from my truck in a field
Edited by SarahsGMC
I would do either a N/A lq9 souped up or twin turbo a mild built lq9 :D
But all that is expensive lol
I wish I didn't have to fix my trans I'd get everything I want done this week bahhh
What gear ratio gears you looking at? If you plan on going with bigger tires in the future gear for those cause regearing is $$$
I'm not doing bigger than 35 ever I do a ton of driving I'm doing 4.56
Edited by SarahsGMC
I do a good bit of driving too and on my 35's currently with 4.88's it sits at 2k rpm at 60 mph. Not that bad and it's really snappy. It would be equivalent to a stock truck with 4.10's
Subs and box came today and my brothers stuff came too lol
This is the difference I'm going from deep 12s to shallow 10s
Here's how they fit
Overall they aren't anything special I'll just have to deal with it if I don't want a giant box in my back seat anymore.. I'll miss the deep sound but I'll enjoy the space.
Subs and box came today and my brothers stuff came too lol evyruqas.jpg This is the difference I'm going from deep 12s to shallow 10s usy8upe6.jpg Here's how they fit yte4utyq.jpg Overall they aren't anything special I'll just have to deal with it if I don't want a giant box in my back seat anymore.. I'll miss the deep sound but I'll enjoy the space. sent from my truck in a field
I did the same thing as you except I had to go deep into specs to get the most out of my old shallow mounts. Your subs are probably going to rub and hit against those flap things that fold down with your seats. Mine did and I actually removed those two flaps and that grey trim piece to save even more room. Not sure if you did this also but I used the jacks screw down point and drilled a hole to accommodate it inside and then bolted it down to get it added to insurance incase it was ever stolen. My system consisted of two Kicker 10in compVT's, new model is Comp RT, with a kenwood KAC-9105D. Those things hit HARD and never quit. Was the best set up I had achieved, by myself, and I miss it. Never tried the pioneers so I cannot give you any pointers of the reliability or performance. Hope all goes well!
They suck I can't hear them and when I do they sound hollow and bad. I'm not at all impressed. And the reviews were good.
How are they wired?
This ^^^ and what are the final dimensions of the box internally? What is the amp pushing as well? In case you didn't know, there is a 7 day break in period for the subs, at least, that is what some manufacturers recommend, some even longer. Pushing them hard too soon could cause a sub to kick the bucket. Moderate level should work. You will notice change and if not, send them back and grab the newest Kicker shallow mounts.
They are wired correctly box is .60 Sq ft subs require ideal .70 minimum .35 so they are fine they are 1200 peak 300 rms.sent from my truck in a field
I'll run em for a week and if no better then off they go I just don't know anything about returning products online sent from my truck in a field
They are wired correctly box is .60 Sq ft subs require ideal .70 minimum .35 so they are fine they are 1200 peak 300 rms. sent from my truck in a field
I usually order from sonic electronix, best place to get stuff IMO, they honor their 30 day warranty then they will actually honor the manufacturers warranty by allowing you to send them the defective speakers then they ship you a new set so you don't have to wait. Just have to contact and request a return or swap out. Box isn't ported anywhere is it?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
