GMT-900: Bed location tabs?
Are there any sort of bed location tabs on the GMT-900's? I think my fuel level sensor is bad so I need to replace it and considering sliding the bed back to gain access but I might drop the tank since I'll probably do this by myself since my wife is not strong enough to help.
I don't want to pull the bed and then not be able to get it lined back up correctly so I'm hoping there are some sort of bed location tabs on the bed/frame.
if I remember right there is a peg in the left front corner of the box to help in lining it up
I think I saw what you are talking about. Looks like some sort of plastic push tab.
I guess I could always drill some tiny holes to use to line up the other corners like they do when reinstalling doors and making sure the hinges and gaps all line up.
it looks just like a plastic peg sticking up , from the underside line up where the heads of the bolts where previously when you reinstall the box
When I did my body lift I did not see any tabs but it was very easy to move the bed. I have hadbit off twice (once for the bd) lined up with out a problem both times. If you remove the bumper you could probbly slide the bed back by your self
Sent from my SCH-I535 using Tapatalk 2
